Selecting Offset from the menu doesn't work
It seems that Offset... doesn't work from the menu. Using a solution from an old 2015 post I got around this by typing in OFFSET1 into the command line. Has this been fixed and I'm missing something?
&Offset...:|OFFSETD;
I open a new Floorplan map and draw a simple Smooth Path. I navigate Draw -> Offset, select the Offset Copy option, specify a distance, select the path and click to one side. Nothing appears, even after clicking Redraw. Info -> List shows only the original entity.
I tried the OFFSET1 line command with the same distance parameter, on the same map. An offset path appears after I click Redraw. It also appears when I use Draw -> Offset -> Offset One.
I checked the dungeon menu file as advised above and the value is as specified. I am running CC3+ version 3.94. I installed City Designer a few months ago and have downloaded a number of Annual files, none recently. I am working my way through the Tome and found the issue when working through the Simple Rails example. This is the first time I have tried to use Offset, maybe I have missed something.
The issue is not a big deal for me but I thought Profantasy would be interested that it is affecting more than one user.
I would like to see if I also have this problem. Please can you tell me what style you were using, so that I can make a similar map for myself?
I was using the CC3 Mike Schley Overland style.
I ran some tests with a sample of syles ....
- Create a new map
- Select a style
- Accept default drawing parameters
- Pick an easily visible colour
- Draw a Smooth Path
- Try Draw -> Offset -> Offset Copy
- If no new entity appeared, use Info -> List to confirm none was created
Results
'success' means the offset line appeared
'fail' means no new entity was created
Dungeons
- CC3 Dungeon - success
- CC3 Dungeon metric - success
- Annual Jon Roberts - fail
- Annual Naomis Floorplans - fail
Cities
- CC3 City Basic - success
- CC3 Bitmap A - success
- Annual Jon Roberts - success
Floorplans
- Annual Scifi Base - fail
Overland
- CC3 Mike Schley Overland - fail
- Annual Worlds of Wonder - fail
- CC3 Overland Vector BW - success
It appears that Offset Copy generally works with styles included with a product and fails with styles from the Annual. But there are exceptions: Overland - CC3 Mike Schley fails and Cities - Annual - Jon Roberts succeeds.
Interesting.
I recommend that you contact Technical Support via the last tab on your account page, and give them a link to your comment (http://forum.profantasy.com/comments.php?DiscussionID=9785&page=1#Item_12) so that they can examine your list and run parallel tests.
While I am sure that Tech Support already know about it, they might not have seen the work you have done here.
