How to add CA155 to a mapping wizard ?
I realize I can load the template and work from there.
However, I want to add this to a mapping wizard, overland, so I can make a number of maps with a frame, the same color pallette, etc.
Or would it be easier to load the template, add my own frame, and save it as an edited ( different name ) template file ?
But I really would like to add it to the overland mapping wizard.
Thanks !
Thanks !
It is only a very simple beast - a standard export from FT3 with lots of stuff cleaned out of it and a specialised palette and ready made altitude bar. That's all.
If you want to use the colour palette in other maps you can do that using PALSAVE and PALLOAD.
The wizard adds a frame for me. And it asks what size I want it to be.
Easier way I suppose would be to loadpal and use existing templates.
If you start a new map and load the palette then attach it to the map, you could save that map as a template in the Templates folder, so you don't have to do the PALLOAD thing each time.
Years ago I came up with my own templates, blue/white maps, and got tired of starting from scratch. So I took one of those maps, took out the symbols and some others things, I don't remember exactly what I did, and saved it as a template file.
That is what I'm doing now.
Thanks for the help. I was using loadpal and getting nowhere. Palload works much better.
Whew. I'm all shook up. Well, I'm not Elvis, but I did accomplish something.
