Houses - gone all strange
Hi
I am drawing a city map that I started in CC3 then have been using CD3 to do theroads, houses, etc and I have run into a problem.
The "House" button to insert houses by drawing a polygon has gone a bit odd and I cant seem to change it back.
On the attached image you can see some houses I have simply placed as symbols, and then some orange and a red box. These boxes are all different types of houses from the house button, but no matter what I use I get a big box of colour plus maybe a slightly different outline and/or a huge chimney stack.
If I open a new map I can draw houses as normal with the different styles, but not on this map. I guess this means that somewhere I have messed up a setting, but I cant find it for the life of me.
Any clues would be much appreciated.
Iain
Iain
Unhiding that layer has fixed the issue.
My next problem is the "Random Street" tool
If I left click on it and draw on my map then I get a default set of random houses that are not what I want (too big, wrong type, etc)
So I right click on the tool and bring up the settings, now no matter what settings I put -> click ok and the command bar remains on "Command[STREETOPT]:" and if I click anywhere to start my street the options box reappears.
Hmmm...
while this software produces fantastic stuff, I'm sure that it is doing odd things to my brain.
I've been playing with "random streets" options. All is working fine but... is there a possibility to set the random street to be curved and not only a straight line? I did not find any clue about that.
It's absolutely not a big issue because the method you described works wonderfully, I was just curious about the possibility to do directly with the random street tool both street and houses at the same time.
