Erase somehow leads to Layer Name dialogue
HelenAA
🖼️ 5 images Surveyor
This morning I somehow appear to have mapped the ERA command to the Layer Name dialogue panel and I cannot unlink it. It happens whether I'm using the command line or the button.
Things I have tried:
1 turning the computer off/on
2 saving file under different name
3 opening a different .fcw file
but nothing works.
Disclosure: I have dexterity issues which means I can't use a mouse or track-pad because I shake too much for any precision. Instead I use the Accessibility keys on the number pad to the right of a standard keyboard.
I'm worried that I may have unknowingly mapped the ERA command onto whatever you key in to bring the Layer Name pane up. If I have is there a way of undoing the process short of uninstalling everything?
but nothing works.
You can reset the selection method by going to Tools menu -> Options -> Select Method button and picking the Dialog or Popup option.
(You can also type SELBYD and hit enter on the command line for the same result)
