Dungeon Designer Floor Issue
Hello. I have been making a map and everything was working fine when Dungeon Designer started telling me no matching tool when I try to select the floor tool. It tells me this if I left or right click. If I go to a different map I can select the floor tool (sometimes I have to right click and sometimes right or left click works). Any ideas on how to correct this? I'm stumped and I'm about 8 hours in on a map I need this weekend for a gaming session so any advice would be appreciated.
  • As a last resort you could try a repair install of dd3. But I would see if someone else can give you a better idea first.
    edited October 2017
    That error usually happens when you try to use a tool that doesn't exist in the template for the current map, but it sounds like the problem happens when you just click the Floor button. As long as you're using a map based on a DD3 template, that should work. Hrm.
    Can't guarantee this'll work, but have you installed the latest CC3+ update? Download it from your account page — be sure to get the correct update, there are separate updates for CC3 and for CC3+. Right-click the setup file and then select Run as Administrator from the pop-up menu.
    Worth a shot, at least.
    I hope it helps.
    Cheers,
    ~Dogtag
    Is your map set up with the proper tool set? Select Map Properties form the File menu, and make sure the correct style is set in this dialog. For a DD3 map, that would be 'Dungeon DD3 Color'.
  • ScottAScottA Surveyor
    I have had the same thing happen, and its always a matter of it being the wrong tool set.
