CC3+ crashing when I minimize a map
LadieStorm
🖼️ 50 images Surveyor
I'm working on a map for the lite mappers challenge over at the guild. We are mapping the Caverns of Chaos... each of us has a specific section.
I started the map, but then I didn't like where it was going, and decided to start over. I already have the two floors of my part of the cave mapped on the previous version, and it was painstaking to create each of those floors as one continuous piece. My two floors in this dungeon are not connected, but are on separate levels of elevation, so I'm trying to show that in my map. I realized I messed up in the beginning, and that I should have set it up like Shessar's Cliffs, which she showed me so many moons ago
The problem I'm having is this: Since I have already drawn out the cave floors, I want to import them from my previous attempt. So what I've been trying to do, is to open the previous map, minimize it, then open the new map, so that when I need to import, I can move between the two maps. But every time I minimize attempt #1, I get the message that 'fcw.exe has stopped working and needs to close.'
I figured that maybe that fcw had somehow become corrupt, so I decided to start the new map, get it to where I'm ready to import the first floor, then minimize attempt#2 to open attempt #1, copy my floor, close out attempt #1, then bring up attempt #2 and place my floor as normal. So I got my new map to the point where I was ready to import the cave floor, and minimized it... only to get the dreaded 'fcw.exe has stopped working and needs to close.', and like an idiot, I didn't save before I tried to open the new map. So now I have to replace all those rocks....again...
But I won't be able to import the cave floors if the program keeps crashing every time I minimize a map. Is this something that a repair install will fix?
Do you actually minimize the program or do you just open a new instance?
Are you using any 3rd party material or is it just ProFantasy stuff?
Have you tried using SAVE AS to save the problem file as a new FCW?
Also, you don't need two instances of CC3 open to copy from one map to another. You can copy to the clipboard, close map 1, open map 2, and then paste.
If so, don't do that, because CC3+ can only have on map open at any time anyway, so once you open a new map, the minimized one will be closed no matter what. If you want to have both maps open, you need two separate instances of CC3+, and then minimize the entire CC3+ windows instead. As Dogtag says though, you don't need to have both open at once.
I remember that when I was working on the first version of the map in question, there was a power surge that ran though the house, followed by a power outage that lasted for about 2 hours. (It went through the whole region) It cut my laptop off just as I was saving. I think that may have corrupted the file.
Anyway, I didn't like the way the first version of the map was going, so I was already planning to redo it. So it's not that big of a deal.
