toggle menu
Sign In
Register
Sign In
Register
Sign In
Register
Home
Mapping with ProFantasy's Software
Is this fixable?
rgrove0172
September 2017
in
I noticed this oops after half the map was completed. Is there anyway to fix the errant line along the frame?
413K
Share on Facebook
Share on Twitter
Shessar
🖼️ 33 images
Surveyor
September 2017
edited September 2017
Easy to fix!
Click the Delete Node button (The one with the minus sign near bottom left button bar)
Click the node at the 'tip of the triangle'
This should fix it. You may have to do it again on the outline of the landmass if there is one.
61.2K
Share on Facebook
Share on Twitter
LadieStorm
🖼️ 50 images
Surveyor
September 2017
another way to fix that is to move the same node back under your border... that would fix it too
Share on Facebook
Share on Twitter
🖼️ 280 images
September 2017
I also use the Node Edit to pull map edges back under the map border. This happens when I fractalize oceans or land masses that are partially under the map border.
It can be a pain to do, but can make for a nice map.
Share on Facebook
Share on Twitter
🖼️ 280 images
September 2017
Looks like LadieStorm and I had the same idea.
Share on Facebook
Share on Twitter
rgrove0172
September 2017
You guys are great, thanks!
Share on Facebook
Share on Twitter
Sign In
or
Register
to comment.
