My first boat
Lorelei
Betatester 🖼️ 46 images Mapmaker
So, i'm working on a commission project where i need a symbol of a galley with an upper deck and a central hold. I love to fish and boat on my dad's vessel, but myself know NOTHING about boats or anything nautical, for that matter. Anyway, there is a pretty limited supply of symbols meeting my needs and decided to try to to make one myself and convert it to a png symbol. Does this look like a Galley with an upper deck and central hold????? Here's what i've gotten....I give you the S.S. Lorelei (hee hee) Thoughts? (i know it's pretty plain, but this IS a symbol, not a map - although i am sure now i will be using it as such in my own campaign:) )
Nice first try
I think the sail area may be a bit small, but you don't want to cover the battlemap with sails, I know
Cheers,
~Dogtag
Cheers,
~Dogtag
If Galley is correct, add oars and lose the masts, If barge, lose the small mast, move the renaming mast to the as close to the middle as possible and put cargo hatches on either side of the mast. Any rigging is probably too much for a symbol.
I think many people get the word Galley mixed up with the word Galleon. A Galley is two things in nautical terms. The first is exactly what pvernon described. The second is the place where the sailors all sit down to eat.
a Galleon however, is a very large ship with lots of sails, a few decks to it, and plenty of space for cannon and cargo. Those are what most people think of when the word Galley is used.
You might wish to reference this article for a "galley": https://en.wikipedia.org/wiki/Galley
Some galley's had sails (some even more than one), but the primary propulsion was by oars. Sail area is of no consequence in terms of your galley as that was an "auxiliary" form of locomotion anyway.
Though, relative to those sails, you would see the mast behind the spar - yours doesn't show that. Instead you've got it such that the spar is actually resting on top of the mast. In fact, the spars wouldn't be near the top of the mast at all - quite a ways down. Also, the mains'l's spar is bit long to starboard.
I'd say your boat is a little closer to a barque (or barc)...
