Who else wakes up every morning and checks if another Annual has been converted to CC3+?
 caveCrawler
                Traveler
caveCrawler
                Traveler
                    It's the first thing I do now.
I want Annual 5 so bad... Treasure Maps.. yummy...
I think Dogtag should use his magic powers to get all the rest converted.
@robotrock: Annuals 2013 – 2017 (Volumes 7 – 11) are compatible with CC3+ so far.
I'm honored, but confused. Not sure what I might've done to earn that, but thank you.
(EDIT: Coincidentally, however, I am working on the Annual conversions for ProFantasy.)
Sadly for me, the ones I want the most are vol 1-7 (2007-13). I stopped getting them after that cause I had defined my style for my campaign world by then.
I guess I can try to convert them manually...
I look forward to an Annual that helps me with SPACE: 1889 ! Victorian age aether ships, etc.
I had forgotten I recently bought the pdf of the game, and a ships book, from drivethru. I can trace those and make some drawings, or symbols. I can use bullzip printer to print a page to png and then import for tracing ni CC3/CC3+.
Of course, if you want to make some go right ahead. I will post them on my site under 'hosted for others' and use them on my pastfuturemars site as well.
Hoping for the countdown to go on... welcome soon, 2012 Annual!
Heh heh. But I'm working on it. Working on Volume 5 right now, actually. Just remember, after I'm done with the conversion, it still has to get reviewed, tested, and possibly tweaked. Plus Volume 5 also contains additional programming code, on top of the mapping content. That may need work from the dev team.
hahahaha!! thanks for your work though!
I'm REALLY looking forward to the older annuals being converted to CC3+. Converting either #5 or #6 next would be great.
Thanks for all your hard work!
