[City Designer] Tree symbols being placed below Elven three houses after activating sheet effects.
Hi, I don't know what is causing this problem. I extracted the proprieties of both symbols and they both are in the same layer.
(Before activating sheet effects)
(After)
(After)
Are you talking about layers... or sheets. Its not the layers that control the order in which things are drawn but the sheets. You need to adjust them, not the layers.
