Drawing filled polygon on top of symbol? How to stop it from disappearing on redraw?
Hello,
I am drawing a filled polygon on top of a symbol but when I redraw, it disappears (maybe it goes behind the symbol?). Can someone tell me what I am doing wrong and how to fix it? Thanks in advance!
Draw your polygon, then right click the sheets button (three yellow sheets on the button to the left) and select Move to sheet... Then select your polygon and move it to a sheet that is drawn after the one with the symbol on it (which will appear in the list of sheets as if it is underneath the one the symbol is on)
The way I do this is to hide the sheets o e at a time. Once you find the sheet it's on, move that sheet down. Slow the symbol sheer.
