CC3 Plus - Thoughts
 AWizardInDallas
                Traveler
AWizardInDallas
                Traveler
                    I've been a user for many years and enjoy the software a great deal.  However, I have a difficult decision to make, which of course has to do with the incomplete state of mostly the annual material.  I have used this material in a large number of maps and would like to continue doing so in the new software.  I have been using CC3 on my laptop, but finally splurged and bought a great PC.  I'm keen to migrate away from the old version of CC3 and adopt usage of the CC3 Plus entirely on my more powerful, new PC.  I realize the software has not yet been released and I'm certainly not complaining, just sharing my thoughts.  Also, I have noticed that both versions don't really run very well together on the same machine.  For one thing, file extension association is entangled and I'm not sure the directory structure doesn't suffer the same issue.  I definitely want to install only one version on my new PC and would welcome advice.
Rich
                            Rich
I just make sure to load the program, then the map, I want to use. I haven't had any interaction between them.
I have them in different directories.
C:\CC2
C:\Profantasy\CC3
C:\Profantasy\CC3Plus
Obviously, file associations can only be set to one or the other (that's how windows works), but you can easily change the association as often as you like or just open files from within the program.
There seems to be file and directory issues on CC3+ even without having CC3.
This is especially true if you are mixing symbols from different sets.
But a custom symbol catalog can alleviate this challenge.
I still need to make my own custom catalog - which I hope to do over the Christmas break.
To accomplish that, ProFantasy has developed different installers for the compatible add-ons. Be sure to use the correct installer, depending on which program you're installing for (CC3 or CC3+). If you want to use CD3 with both CC3 and CC3+, for example, you'll need to install it twice, once for each program, using two different installers. Again, both versions can peacefully coexist on one machine, but maps made via CC3 may not display correctly, for now, in CC3+, and vice-versa due to the different underlying folder structures. That's going to depend on whether you have the same add-ons installed for both products. The primary culprits causing trouble right now are the annuals.
The new Perspectives version coming out in a few months, on the other hand, will be an upgraded product and will only work with CC3+.
Cheers,
~Dogtag
From what I understand, it is a naming issue.
Monson told me how to make my own symbol catalog to overcome this, but I just have not had the time to set down and do it yet.
If each style had unique names for it symbols, it would expand the usefulness, and therefore value, of the product offerings.
I decided to make the arcology dungeon, mentioned in these forums, in CC3+.
As for a list of what is compatible, its been mentioned several times in here, a search will find it.
I'm slavering for the updated annuals, too, but, to be realistic about this, there are core products that have to come first, including the finalized** CC3+ and genuine "plus" versions of CD3 and DD3.
**(Correct me if I'm wrong, but isn't this "early adopter" version that's out essentially a late beta or release candidate?)
There is also a new version of the software (CC3+) in development. At some point, after it has been released, the annuals will all be updated to work with that version as well (free of charge, to current annual users, if I understand correctly).
Everything said in the last few posts is perfectly true, which is why I wouldn't recommend installing ONLY CC3+ (as the OP suggested he might). There's still too much that doesn't work with it. If I HAD to choose, I would probably install only CC3 at this time (but I don't have to choose, so I installed both).
One thing to be careful of is that, on a Windows system at least, only one of them (CC3 or CC3+) will be associated with FCW map files, so only one of them will open maps by double-clicking the file within a file browser. Both of them, however, will open maps normally via their respective File>Open menu commands or Open toolbar buttons.
Cheers,
~Dogtag
I was thinking about this earlier, though, and I may try to "convert" an annual when I have a chance, just to see what might be involved. I know that some annuals add toolbar buttons and macros, and that might be tricky, depending on how paths are referenced.
Or, I could be completely wrong. It's bound to happen sometime.
~Dogtag
Personally, I prefer having both CC3 and CC3+ installed side by side. There are no problems with this, except from the fact that only one can "own" the file type, so you need to open maps from inside the appropriate program instead of double-clicking the map files, and obviously, it takes more space on your drive. I like CC3+, it is quite a bit better than CC3, and I use it when I can, but for a lot of my maps, I still use CC3.
To alleviate the minor problems I mentioned above, I did two things, I added an 'Open with CC3' and 'Open with CC3+' to the right click context menu of .fcw files, and I use file system soft links to share the artwork directories between the installation to save space by not doubling up on artwork (which is the space-consuming part of CC3(+), the programs themselves takes up next to nothing). Both these things are quite technical and can make a big mess if you do them wrongly, so I strongly recommend that you only attempt doing this if you already know how to do it.
It sounds to me like I could download CC3+ as a complete and separate program from CC3, like having The Elder Scrolls and The Witcher on the same drive. If that is the case I might just do that. I have no desire to go through a bunch of technical fixes to make the software work with what I already have.
1. World/Regional Maps
2. City Maps
3. Buildings, dungeons, and battle maps.
Right now, the only thing I am missing is Character Artist to provide the inhabitants for my world.
There are a few hick-ups, but as mentioned, this is an early adopter program.
It is good that we mention challenges involved with the product though so the makers can adjust fire.
But I have to say, I really love this product. :-)
I remember being an early beta tester for Field of Glory from Slitherine.
It went through all kinds of changes based off of our feedback.
It ended up winning awards.
Some of the scenarios that I designed actually made it into the game.
I don't mind working through the bugs with early adopter and beta launches because I know that the process makes for a superior product.
It feels great to be part of that. :-)
Those who are impatient should buy Remy's "Tome of Ultimate Mapping," which will teach you much of what you need to know to convert the annuals yourself. Additional things include:
1. Opening macros, menu files, etc., and changing "#" to "@".
2. Open each catalog of the annual file (.fsc) in CC3+, enter the command FFIX + the Enter key and save the FSC file. That converts it to a CC3+ catalog.
3. Click the Symbol Catalog Settings icon and add the catalogs from the annuals to the right catalog group (or create a new one). Save your new settings.
Mark Oliva
The Vintyri (TM) Project
info@vintyri.org
Holiday Cheers,
Rich
