Windows 8 install problems
                    I've got CC3, CD3, DD3 as well as the symbol set 2, annual 07-08.  When installing I keep having issues with the initial install of each of the core 3.  They will through an error saying " is not an integer value.  After a repair instal everything will work but the menu buttons won't show up.  I can use the CD3 menu fix to make some show up, but ironically nothing I have installed will pop up.  Also the CD3 has to have its registry serial code manually entered.  If I load a CD3 or DD3 map the buttons will appear, but once I click the CC3 button they disappear again...
I've tried to uninstall then reinstall, but all the old registry stuff and test maps remain. Any thoughts on this would really help. Even if it's just how to do a complete clean install.
Go to your CC3 program folder and run "CC3MenuConfig.exe" manually, by right-clicking and choosing "Run as Administrator". This should fix the menus, the only thing the install fails to complete correctly.
Try opening the Windows registry and delete the following entry:
HKEY_CURRENT_USER\Software\EvolutionComputing\CampaignCartographer3\SerialNum
That should allow the CC3 setup to continue past the EULA.
Let me know if you need instruction on how to edit the Windows registry.
