CC3+ Problems
Running on Windows 8.1 64 bit
When I first loaded the software everything was fine. After trying out several test maps the New Map Dialog lost its previews as seen in the image below.
When I tried a new map a second time, I ended up with the blank template images again.
Cheers,
~Dogtag
I even tried the install as admin with the same results.
I'll have to assume that there is something on my PC that is messing with this, since no one else is having this problem. I'll post when I figure it out just in case some else runs into it. Thanks for the info j.
The ~BRINFO.FC$ is there immediately after install, before CC3+ is ever run.
If I delete this file before running the first time, everything works as it should ... Until I exit and start again.
This file is in all of the templates directories before ever being run and I have this problem with all Predefined Templates.
Wondering if I have a corrupt installer. Will download again and reinstall again.
Oh well, guess I'll just have to deal with not being able to see the new map template previews for now. Thanks for your help jslayton
After lowering the DPI Scaling to 100% nothing changed.
I then lowered my screen resolution a couple of notches so that I could actually see what I was doing and the previews came back.
I'm curious what results I'll get. But I just haven't had time yet to give CC3+ a fair shot.
If you run as a User, do you start CC3+ by double clicking the icon or by right-clicking and then running as Administrator?
When you install a program as a User, a little popup asks for the password for an Admin account, and once given the install is completed as the Admin account. If CC3+ deletes and recreates the preview file, and your not running as Admin then the issue might be that your account doesn't have the permission to delete and recreate the file.
I've not had a chance to install and test out CC3+ yet, but I have a few programs on my computer that seem to have been developed on the assumption that the user is logging into an Admin account rather than being security concious and logging in as User. Not saying that this is the case for CC3+, but that's the sort of error I usually see when running certain post-windows 7 apps as a User rather than an Admin.
Thanks.
[edit] I didn't see the "Got it to work." comment though
O1i, I am installing and running under an admin account. In fact, I'm not sure what the problem is. I booted up my system today and the problem had returned.
At this point I've uninstalled and reinstalled so many times and tried changing so many different display and folder settings that I've screwed something up. I'm going to do a fresh OS install then see what happens from there. Since there only seems to be a couple of us having this problem I am going to begin with the assumption that there is a problem with my system. Maybe a fresh OS will fix it.
I'll be back in a day or two with a report and figure it from there.
Thanks for all of the thoughts and input everyone.
I'm tired. I give up.
Would a touch screen have any bearing on this? I wouldn't think so, but odd things do happen...
So far, I have had 100% success if I delete the preview cache file(s) and restart CC3+. However, the caches will have problems on the next restart of CC3+ and show black previews again. Annoying, but I'm trying to figure out why it's doing it. I find that making a C:\ProgramData\ProFantasy\CC3Plus\Templates\cacheflush.bat file makes things a little easier for the very near term. In the file are the two lines
attrib -h ~brinfo.fc$ /s
del ~brinfo.fc$ /s
The first one removes the hidden attribute on all of the preview caches in all of the template subdirectories, while the second lines deletes those now-visible files. It's certainly not correct behavior, but it's a way to get the previews back for a session.
If anyone else decides to use the batch file, don't just copy and paste the above, make sure to hit enter for a line break after each line of code but no blank lines.
Would that make a difference ?
Just to clear up a bit of confusion on the installation directory of CC3+. CC3+ does not allow you to change the installation directory, so your CC3+ installation is in c:\program files(x86)\ProFantasy\CC3Plus. What the installer lets you change is the CC3+ data directory, the directory where all user-editable content is stored (Which does make up the bulk of the installation though). Notice that this change also makes all the old advice about installing to a different location completely obsolete, since user data no longer is installed in the Program Files folder.
Ooh -- that's not good. I have a tiny solid state drive for C: that I try not to load much onto. I really don't want CC3+ loaded on this disk, even if the data is being placed elsewhere. Can that be changed before the CC3+ release is finalized?
Steve
