Object displays partially filled
This occurs more with zoom in and goes away on zoom out. Printing (to PDF) looks fine. This appears to be a display only issue. I've seen this several times and seems to relate to filling with a bitmap, etc, as opposed to a solid color. But I have not tracked down exact steps to reproduce.
    If possible, avoid that specific bitmap fill, it's a holdover from very early times and might not be setup correctly. Use one of the CD... bitmap fills instead.
    You can fix this particular issue by setting this bitmap fill ("Stone") to "Tile to Fill" in the Fill Style dialog.
  • arcarc Newcomer
    With the install of update 11, I was able to follow the tutorial almost exactly. Previously things were missing or wrong. That means I did the bridge the way the instructions said, which totally avoids this problem. I'll have to keep an eye out for this one.
