Using a CC3 annual fill style in CD3?
I'm working on a village map, and instead of having to draw in individual fields, I am wanting to use the Herwin Wielink farmland fill to create filled fields. Unfortunately, while trying to do so, I can't get them to appear while working with CD3. Trying to force it gives only a white sample block, I'm not sure how it will look inserting a 3/4 view graphic into a top down view, but I'd like to see.
    You'll first have to import the Herwin Wielink style fill styles into the CD3 map.
    To do so,
    - open your CD3 map
    - then go to Draw > Insert File and
    - open the file "CC3/System/Bitmap Fills/CA71 Bitmap Fills.FCW".
    - Place it in your map, then delete it again.
    The fills will remain available.
    Hope that helps!
