Using a CC3 annual fill style in CD3?
I'm working on a village map, and instead of having to draw in individual fields, I am wanting to use the Herwin Wielink farmland fill to create filled fields. Unfortunately, while trying to do so, I can't get them to appear while working with CD3. Trying to force it gives only a white sample block, I'm not sure how it will look inserting a 3/4 view graphic into a top down view, but I'd like to see.
To do so,
- open your CD3 map
- then go to Draw > Insert File and
- open the file "CC3/System/Bitmap Fills/CA71 Bitmap Fills.FCW".
- Place it in your map, then delete it again.
The fills will remain available.
Hope that helps!
