Kliene Berg City map CA85 style
I had a spare few minutes this morning and decided to play around with the WW2 area style in CA85.
This was just done off the top of my head with no real world reference so I'm sure there are a lot of things that don't quite make sense. But overall I like the style and how quickly a map in this style can come together. This was about 30 minutes of work.
Thoughts or feedback on what works or what should be updated?
KenG
-edit for size
KenG
-edit for size
Any good ideas on what I can use for bridge and tunnel symbols on this thing?
KenG
Also redid the train lines.
So any opinions?
Thanks,
Was bedeutet "kliene"?
What are the green-blue areas? Suggestion: you could perhaps blur the edges between green and green-blue...
Did you meant "Kleine" (small)? In that case I think the right ending is "Klein".
A blur or edge fade might help.
Thanks for the comments
Nix für Ungut.
Thanks,
KenG
Here is a slight update with a change in the forests and sheets.
Thanks,
KenG
Monsen you were right I didn't have the anti-alias turned on and I think that helped out a lot.
Thanks to everyone for all the help so far with this one,
Please keep the feedback coming, I'm learning more and more with CC3 on each comment.
KenG
