WW2 Interactive Atlas Installation Issues
Hi Folks,
I know I solved this back in the day but now I can't find my notes.
System: Win 7 64bit
I've got CC3 & CC2 re-installed. So far both appear to be working just fine. Installed just about everything (all addons except FRIA, WW2, & Annuals).
Now the issue: The WW2IA keeps wanting to install itself under my CC3 directory. BUT I know it will only "work" with CC2 - which is why I've installed CC2 in the first place.
I even tried installing it as a standalone and the install keeps telling me it will install the "upgrades" into my CC3 directory.
Obviously the symbols and maps can be copied into CC3 (which is exactly what I plan on doing anyway) BUT I would like to be able to use CC2 to work within the system at times as well.
Any ideas on how to get around it? And does anyone know if I'll have the same issue with FRIA and the annuals?
Thanks
john
System: Win 7 64bit
Thanks
john
Ralf? Can you chime in with what registry key the installers are looking for? This way I can manually change it? Thanks
John
Fwiw, I got the annuals and the FRIA to all install just fine. So it's just the WW2IA that's causing problems.
Oh well, back to work, lunchtime's over
Hopefully Ralf will chime in soon.
Steve
interestingly the symcrypt exe program has a similar issue: it can't find CC2
Not sure why symencrypt fails. It finds CC2 nicely on my system. Maybe try with a reinstallation of CC2, then immediately install WW2IA and symencrypt before running CC3 again? Again, I can't test this, so I don't know if it works. All I know is that I have basically once upon a time did exactly what you are doing now. I have both CC2 and CC3 installed, with the WW2IA and everything else (Although my CC2 installation have somehow gotten a bit messed up lately)
There was a registry key (fastcad) that when I changed "cc3" to "cc2" I got the ww2ia to install and run. Still no luck on the symencrypt though...
Here's the registry key: HKEY_CLASSES_ROOT\FastCAD
And here's what to the *.reg file I exported (before changing anything) had (obviously put in your own directory structure):
Windows Registry Editor Version 5.00
[code]
[HKEY_CLASSES_ROOT\FastCAD]
@="CC3 drawing"
[HKEY_CLASSES_ROOT\FastCAD\DefaultIcon]
@="C
[HKEY_CLASSES_ROOT\FastCAD\shell]
[HKEY_CLASSES_ROOT\FastCAD\shell\open]
[HKEY_CLASSES_ROOT\FastCAD\shell\open\command]
@="C
[HKEY_CLASSES_ROOT\FastCAD\shell\print]
[HKEY_CLASSES_ROOT\FastCAD\shell\print\command]
@="C
[/code]
