Jon Roberts "Lake" Tool
Hello Hive Mind,
When I am waiting inspiration to continue my "real" world map, I am doing a rapid one using Jon Roberts style (CA 51 I think). But I am having a little problem with the "Lake" tool. I want the lake to be a smooth one OR (and this is what I prefer) to be a nice fractalization. But when I use the "fractalize" tool I got the result on the image. Does anyone know how I can solve it?
Seeing that your standard coastline doesn't seem to have the blue outline, I'd simply delete the lake outline. If you want it gone from the tool for future use, simply click the Advanced button in the drawing tools, select the "River, Lake" tool, click "Outline" and set it to no outline.
Alternatively, if you want to keep the blue outline of the lake, simply use the Fractalize tool on it with the same settings as on the lake body.
P.S.: May I suggest to go a little easy on the fractalization? Your coastlines already seem to have A LOT OF nodes, and you might run into handling/editing problems if you add much more.
We really should update fractalise so it works on mulitple or at least stacked entities.
