Can't install DD3
I have CC3 installed (obviously) in C:\Profantasy\CC3 as recommended elsewhere. When I install DD3, it asks for .NET framework to be downloaded - the download linnk takes one to a page to download .NET v2. But I've already got .NET v4 on my system! Windows 7 x64. I can't install DD3 because I don't want to download an earlier version of .NET. In fact, I don't want or need to download any version of .NET!
Why can't these installers actually detect what is already on the system, eh?
Ok is there a work around for this, puleeze?
However, there is no means of specifying where it should be installed - my CC3 folder being C:\Profantasy\CC3.
When I get to the list of things being installed, there is DD3 but it has a red X next to it - if I change the red X to install on local drive, the disk space at bottom shows I have -1 bytes available for the installation, and it falls over with Error 2343 when trying to install into \mia84BA.tmp\data. If I continue I get another Error -11: CC3 update 10 unable to install new files. And then the installation ends.
And yes I am running it as Administrator
1) Does your CC3 install work as it should? When you start an overland map, can you switch symbol catalogs by clicking the symbol catalog buttons right above the drawing window? Does the symbol catalog window appear on the left side, and not the right. If you had to answer no to any of those question, there is something wrong with your install, so you should start by reinstalling CC3.
2) Try to install CC3 Update 10 (Downloadable from your registration page) before running the DD3 installer.
Thanks for your help!
Need to start getting all the other goodies now
I got a new computer running Windows 7 x64 and I'm trying to set everything up on the new computer. First time around (using my old CC3 disk), that program created and installed on c:Program Files (x86)/ProFantasy/CC. But nothing else would install, or even open up. So I moved it to c:/ProFantasy/CC after reading the above, was then able to run the CC3Update10, and then DD3 installed, as well as CA2007. So thankful for the above comments!
However, I cannot get cd-cc3-compatibility to install, even though I downloaded it from my registration page, instead of using my disk. I did try to download the .NET driver, and my computer rejects 1.1 and 2.0. It did accept 4.0, but the cd-cc3-compability program still wants 1.1 Service Pack 1.
I am having the same problem with ss1-cc3-compability and ss2-cc3-compatibility, both of which would not load from my disks, so I downloaded them again, and they are still making these unreasonable demands of me.
If someone has a solution to these problems, I would appreciate it.
Regards,
Elle
If this does not work for you, please submit a tech support request from your registration page. That will make it easier for us to help.
BoomerET
