CC3 - Template, Landmass and Texture
Hello Hive Mind,
I have doing a map in CC3 using a certain template and a texture. Now I have very nice and detailed ladmasses (a lot of detail put in the fractal of the costs) but I want to "paste" it on another template (diferent number from original) and want a diferent texture to my land masses cause I really loved the CA60A - Climate Textures and the brand new CA62 - Overland Satellite Maps. So there is someway to do it?
Thanls in advance,
Mateus
Thanls in advance,
Mateus
- Open both old and new map at the same time (CC3 can run in multiple instances).
- Do Ctrl-c in the old map, select your landmas, right-click, Do It. Select 0,0 as the point of origin.
- Switch to the new map and hit Ctrl-v. Type in 0,0 for the point of insertion, right-click to finish.
You now have the landmass in the new map, but it doesn't look right yet, because it's in the old style.
- Right-click the Change Properties button and select "Change like Drawing tool".
- Right-click and choose the "Land, Default" drawing tool in the list that comes up.
- Select your landmass again, right-click, Do it.
That's it. Your landmass should now be in the new style.
Fisrt I hided everything in the map except for my land mass. Then I went to Edit then Change Propriets. Then selected all my land mass and "do it". But now I dont know what to do in the box that opened...
Note that it is even easier if you follow the instructions Ralf provided, i.e. Right Clicking change properties and select "Change Like Drawing Tool". This will bring up a list of all the drawing tools for you to select from instead of the change properties box. It is easier to see visually what you are changing into this way, and you don't need to think about the outlines, since the drawing tool handles both at once.
Thank you.
