Cosmographer 3 and 3D Grids
New user to CC3, I bought this just for Cosmographer 3. I'm having troubles figuring out how to do something I think should be simple, but isn't turning out that way.
I want to create an isometric grid that has a definable position for X:0 Y:0 Z:0 and then place planets (or nav points, or stars, etc.) at specific points on this grid.
For example: Nav Point 1 at X:100.08 Y:-50.07 Z:0 and Nav Point 2 at X:132.91 Y:-30.36 Z:-22.00
I don't see any edit options for the symbol of a star (which when I figure out how to bring in custom shapes I'll change to what looks like a good navigation waypoint), which I'm using as Nav Point 1 that will let me place it at specific x y z coordinates.
Would be very nice to have that manual about now (over 2 months since it was last mentioned in these forums). Anyone who knows anything, please help.
    edited December 2010
    Don't know how to edit an existing symbol to change the position to a specified Z-coordinate easily, but when you place the symbol, you can get exact coordinates.
    - First, select a height symbol from the symbol catalog. Then, instead of placing it manually, type in the x and y coordinates on the command line (in the form of x,y - for example 0,0), then hit enter
    - Now, the symbol asks for the height. Type the z coordinate here, then hit enter.
    Edit: Ok, I spoke a bit too soon here. I forgot this was a isometric grid. You'll need to calculate the the appropriate x/y coordinates using standard trigonometry. The z parts remain as described above. Also, if you configure the snap grid using appropriate values, and turn on snap and cursor snap, you should also be able to place the x/y part easily by hand (Assuming that your coordinates are integers, or something expressible as a fraction with a common denominator)
