Community Atlas - Seven Maps from Seven Maps of the Day
 Ricko
                🖼️ 106 images Mapmaker
Ricko
            Instead of searching for a spot on the Atlas, this time I'll try to make seven simple maps (less than 30 minutes each), from the seven maps of the day suggested on the community's Atlas page.
Let's see what comes out 😅
Ezrute - Dunor Valley - Dunor Region - Mate Mill - map of the day - October 29 - 2025
Where is Mate Mill on the map, @Ricko
In the upper right corner. The only illuminated spot.
This time, randomness led me to the cold region of Uppsala. I chose to bring to life the small and resilient village of Nora.
Bonus track! Based on a floor plan from an archaeological dig, I tried to reproduce the size and layout of the rooms similarly to create Nora's Longhouse.
Edit: Final version with the Terrain that I had envisioned on the map. Thank you very much @Wyvern for recommending the post @Loopysue for explaining the matter in the post and @Monsen for making the video.
For the longfire, I used Mike Schley's fireplace, distorting its size to a 1:7 ratio.
I don't know if I'm being overly sensitive today, but this map took me a while to complete; the 22 minutes it took me felt like a mini-eternity in my head. It reminded me of long conversations that I now only have in a chat room that I won't read.
I tried to follow his instructions as closely as possible to breathe more life into the abandoned inn he described.
