CC3 is Installing Data on the Wrong Drive
Hello,
I just bought the CC3 Humble bundle and have been trying to install it. I specified a file on my D:\ drive as my C:\ has limited storage. I got through a number of add on installations when I got notification that I couldn't install the next one because there was no space. I found that it had installed data on my C:\ and figured I must have messed up and bypassed changing the directory during the install of some of the add ons. I uninstalled using each add on's loader, down to the base program. I still found files on my C:\ though. I uninstalled the base program, reinstalled, specified my D:\, and found that installed some files onto my C:\ and some on my D:\. I only use my C:\ for critical programs. I don't know why it is splitting files on two different drives, especially when I specified that it needs to go on one of them. Is there something I'm not doing right with this or is this a problem with the program?
Thank you
Answers
The CC3+ files are split into two locations:
If you really need to, you can move the program files folder (usually C:\Program Files (x86)\Profantasy\CC3plus) to a different location after setup. Just move the folder over, adjust your desktop shortcut to point to the new location and run CC3+ once).
