CC3 is Installing Data on the Wrong Drive
Hello,
I just bought the CC3 Humble bundle and have been trying to install it. I specified a file on my D:\ drive as my C:\ has limited storage. I got through a number of add on installations when I got notification that I couldn't install the next one because there was no space. I found that it had installed data on my C:\ and figured I must have messed up and bypassed changing the directory during the install of some of the add ons. I uninstalled using each add on's loader, down to the base program. I still found files on my C:\ though. I uninstalled the base program, reinstalled, specified my D:\, and found that installed some files onto my C:\ and some on my D:\. I only use my C:\ for critical programs. I don't know why it is splitting files on two different drives, especially when I specified that it needs to go on one of them. Is there something I'm not doing right with this or is this a problem with the program?
Thank you
Answers
    The CC3+ files are split into two locations:
    1. Program files (exe and dlls): This goes into your default Windows program folder and is not adjustable during setup. The size of the folder is small and will not increase significantly with any further installs.
    2. Program data (everything else): This is adjustable during setup. It contains the vast majority of data in CC3+ (all the image source files for example).
    If you really need to, you can move the program files folder (usually C:\Program Files (x86)\Profantasy\CC3plus) to a different location after setup. Just move the folder over, adjust your desktop shortcut to point to the new location and run CC3+ once).
    LoopysueRoyal ScribeDon Anderson Jr.
