Current State of CC3+ on macOS
CNYGamer
                Newcomer
            Hey all.
In the past I've used CC3 and CC3+ on Intel-based Macs with Wine CrossOver and with Parallels with varying degrees of success. Where I ultimately landed was just to run CC3+ on my Windows box.
Now I have a shiny new M2 Pro MacBook Pro and I really want to get away from running CC3+ on a Windows machine if I can help it. Literally everything else I use for managing and running my games is on my MBP, and having to swap over to a different machine to run CC3+ is a mild annoyance.
I'm interested in hearing about any first-hand experiences, particularly from people running CC3+ on an Apple silicon Mac. Is Wine CrossOver my best bet? Parallels? Continuing to run CC3+ on my Windows box?
Thanks in advance for any info and advice.
Edit: Replaced 'Wine' with 'CrossOver' for better specificity.
I have an M1, and I run CC3+ with Wineskin without issue. I'm not exactly a power user, but it fits my needs. I also occasionally run it in Wine on an Ubuntu machine and use RDP to display it on the MacBook. Long story as to why I do that, but technically it does work well.
It's Wineskin 90% of the time when I'm on the M1.
Thank you for the feedback, ThatKert.
What I ended up doing was downloading the 14-day trial version of the most-current version of CrossOver. I installed all of my Profantasy software in a bottle and it seems to be working very well. I'll beat on it a bit for the next week or so to be sure, but if all goes well I'll probably purchase CrossOver. I have a years-old license, but the company offered me a generous discount to buy the new version.
I had forgotten what a long, involved process it is to re-install all this stuff. With all the add-ons and the annuals, it was around 40 installations. What I wouldn't give for a web installer that just installs everything you have a license for. 😉
Sounds like you have a plan, but thought I'd add that I have no problems running CC3+ (also with a lot of annuals and add-ons) on an M1 MacBook Pro using Parallels and Windoze 11 (arm version). I have found it interesting that I have a LOT less problems with this setup for 10 years than I had with Windoze on PCs for the previous 25 years. I need Windoze to run some rather esoteric ham radio programming software using serial ports and with that and CC3+ and FT3 it's worked like a champ.
Running on CrossOver has been going very smoothly. I did download a trial version of Parallels but I hit quite a few hurdles getting it set up and attempting to install CC3+ on it, whereas CrossOver was quick and easy. It was also less expensive both for the price of the actual software and for the fact that I don't need a Windows license.
The other interesting thing, and it sounds like it might parallel (no pun intended) your experience, is that installing add-ons and annuals to CC3+ using CrossOver is MUCH smoother and faster than installing them on my Windows box, which is a pretty beefy gaming machine.
So all in all, I'm quite happy with how things turned out. And it's a nice quality-of-life improvement not to have to fire up my Windows box when I want to work on maps.
Hi @CNYGamer , I have - all in all - the same working like you.
But one question, do you have the problem with fonts in the maps, too? The scaling and placing of text is not really working. It is getting better, when deactivating the "new" improved font rendering and using the old font rendering algorithms in CC3+. But I am not really satisfied on that front currently. How about you?
some fonts have always been an issue but the latest version is not to bad at displaying what the original artist intended
I'm on an M2 Mini and use Parallels because Crossover doesn't work on the M series. I would love to be able to run CC3+ straight from my Mac - would save me money as well! There is a learning curve with setting Parallels but it is what it is, sadly. but because we're in the [probable] 0.1% of PF users we're left with paying out if we want to use PF.😥
as far as i am aware crossover now does run on m1 - m4 type apple machines as it also runs 32bit programs in a 64bit enviroment , why not test it using the free trial they offer which is fully functional and lasts for 2 weeks
Rob
sadly, despite what they say when I had installed crossover I was greeted with:
And they wanted £60 GBP for the full version!!!! I'm sticking with Parallels .............
personally i have run cc3+ under parallels and crossover and found that i got a faster program for rendering with crossover , if you want to try crossover you need to install as a unlisted program
another option for the m series of mac computers is to install windows for arm under a UTM virtual machine , this is free for both UTM and windows and runs very well
I've been having a go at trying to install Campaign Cartographer using Whisky
(https://github.com/Whisky-App/Whisky)
Not been able to get further than the initial installation wizard yet before it seems to hang, is that similar to how its been on Crossover directly?
just trying now , crossover gets halfway through the install wizard , this gets a little further as it creates the bottle but gets no further
Any error messages/log file that might help in figuring out what is going wrong under Crossover there?
hi Ralf , this is a copy of the support ticket i raised with codeweavers but have yet to hear anything back
"i have been running the installers for the campaign cartographer for many years , i have recently bought a brand new M4 mac mini , i have imported my bottle of the program from archive and it runs very well however the installer of the program crashes with a memory error as per the attached picture , so perhaps this could be put on your todo list of bug fixes
Rob"
Rob
I install all of my Campaign Cartographer stuff via CrossOver using "Install an unlisted application" and it installs and runs quickly and beautifully on a MacBook Pro with an M2 Pro chip. Zero problems or hiccups of any kind. And as I mentioned in a older post of mine in this thread, it installs more quickly and smoothly than when I install directly onto my Windows machine.
I'm presently running Sequoia 15.1.1 and CrossOver 24.0.5.
I tried Crossover on the M4 MacBook Air. It loads - with challenges (the installer is not able to address all of the security in the lates MacOS) so one must deal with it manually. There is documentation on the Codeweavers site. The show stopper for me is there seems to be no means of setting a specific drive workspace for Crossover or for any of the applications it installs overlays (Bottles) for. While I am sure this seems great to most casual users, for simplicity's sake if nothing else, I can assure you that somewhere down the road it will become a significant problem. Until there is a way to create a "Sand-box" on a given external AFPS drive I would not suggest using Crossover. Exception: IF all you ever want to install s one or two applications and you are not concerned about how full your Mac's internal drive becomes (because it is like 2 gb or some such) then proceed with a smile.
If you want to run bottles from an external drive then you need to edit the crossover.conf file
here is my edit , note you will have to re edit each time you upgrade crossover as the file exists inside the crossover app
my external drive is called 2TB SSD so change that part in the line to match your setup
[BottleDefaults]
[EnvironmentVariables]
"CX_BOTTLE_PATH"="/Volumes/2TB SSD/bottles"
right click on crossover.app and view contents and use the text edit to change and then save
Thanks to Suntzu for that tidbit on updating the data store. I did like the concept of having the application run the way crossover addresses it. Your edit is a great way to deal with the problem for us Tech Folk, however I would caution the uninitiated to make backups of their files on something external (Cloud etc.) A final thought, In addressing one point someone made; that being how long it takes to load all of the add-ons and such, I wonder if there might be a benefit in creating a "Snapshot / Tar-Ball" of the install package (bottle) and any of the control files necessary for recovery - Just in case. Sorry, too many years in the datacenter.
Raemann , i export to archive each month as a new annual comes out , then if anything fails i can re-import from that archive into a new bottle , note you cannot import to an existing bottle or a bottle of the same name. this export is a complete snapshot up to the point you started that archive , mine is stored on an external HDD and at present is 75Gb , i also use time machine on my bottles as well
How did you get past this error? This is where I get stuck. I can get a modified copy to install Ralf sent me but that one has a license issue
I imported my archive from my iMac , Ralf didn’t reply to my licence issue with the new instal setup he sent me
Can I create the bottle on my intel MacBook and move it to my M4 MacBook?
yes you can even do this from a linux crossover install using the same method
what i would do is create an archive (right click on the bottle in crossover ) and export to archive to a place of your choice though i would not recommend to do this across a network , once done go to your macbook and import from network this same file the name of the bottle must be unique to that , if you want to put this bottle on a separate drive there are instructions further up on this thread
Worked on the intel MacBook but the archive will not work on the M4 MacBook. Also tried on a M1 version, still a no go. Guess after a year of trying to get this to work I'm done. Not worth the effort at this point I just wanted to use a single computer instead of carrying two laptops.
what version of crossover are you using ?
another option would be to use UTM and install windows for arm on a virtual machine this would then allow you to install cc3+ directly into the windows virtual machine
Crossover 25.1.1 but have tired earlier builds also with same issues. I have a UTM but the limited screen size makes it to use for mapping.
