[WIP] Swamp Witch
When I was coming up with "spooky season" mapping ideas, I was debating between a haunted house or a witch's lair in a swamp. Why not both?
That required experimenting with some different styles to try to create a swamp. (Let this serve as another plug for a jungle/swamp annual compatible with annuals like Creepy Crypts, Forest Trail, and Marine Dungeons.)
I wasn't sure which way to go...so I ended up doing three versions. One is in the Mike Schley Dungeon (SS4) style, the second used Forest Trails as the basis, and the third used Marine Dungeons (though the second two had to borrow a bit from DD3 and other styles).
I don't know a lot about swamps, but the images I've seen show a lot of trees both on dry land and in the water. In all three versions, I made it so that the tree tops could be hidden, both to create a battlemap version and also to show that some of the trees were growing out of the water and not just from patches of solid land.
Here are all three side by side, and then in the comments I will show each one in more detail.
LoopysueMonsenzace66
