SMAC Files,, Please Help
                    Hello good people. I just downloaded a lot of the SMAC files, AWESOME JOB BTW, and I don't know where to go from there to get these great symbols into my CC3/DD3 program. Being computer illiterate,
I'm probably making this harder then it is but I don't want to screw anything up.
I know I have to make a SMAC symbol file, which I know is under the symbols selection, but I don't know which choice to pick from the drop down menu
After I make this SMAC file, how do I get the zipped, I think thats the word, symbols off my HD and into these folders?
Simple directions would be great, remember that I'm not all that computer savy, and any help would be very much appreciated
2. Now, unzip the downloaded files into this folder. Exactly how to do this depends on if you are using the built in unzip program in windows, or you have installed another one. In most cases however, it is just right-clicking on the downloaded zip file, and select something like "unizp to" or "extract to". Most software will then give you a dialog asking where to unzip the files. These should be unzipped to the SMAC folder you just made in the previous step
3. Repeat 2 for each zipped file with symbols you downloaded
Now, you can use the symbols inside CC3 by clicking on the "Open symbol catalog" button right above the symbol catalog window itself. This will open a dialog where you can browse to the symbol catalog. Browse to the SMAC folder you made previously, and from there, into the desired subfolder. From hereselect the desired symbol catalog file, then click ok, and the SMAC catalog should be shown in your symbol catalog window.
For easier access to the symbol catalogs, you can also add buttons to the menu for these. Look here for instructions
If you're not getting that option, maybe there is a permission problem?
Steve
I was wondering if anyone could help me with the SMAC fill imports. I downloaded all the files and put them in the right directory but when I goto Tools>Import and then try and lay a floor I cannot find the imported fill styles there and they are not listed under the advanced tab. So my question is where are the fills that were imported? and how do I access them?
Please do not double post. It won't help you get an answer faster, and it just wastes everyone's time.
The .fsc files should be in the SMAC folder.
So:
CC3
Symbols
SMAC
Art Files >> .png files
.fsc files
And no, the Art Files directories shouldn't be named "Art Files", as all these directories are on the same level, so they have a package-spesific name, like "Art Altars", "Art Arches" and so on.
