Q: Import real star data into Cosmographer?
 ubai
                Newcomer
ubai
                Newcomer
            Hello,
I know that Cos3 came with a sample map that uses real star data, and I am wondering how that data was imported into the map. Does anyone know how that was done? I'd like to do the same thing for a 2d star map for my game.
Thanks!
That map was created via an excel sheet with the data, and a script file created from that data.
Take a look in your CC3+ programdata folder in the "Scripts" subfolder. You should see a "stardata.xls" file and various script files. If you look at the spreadsheet that it contains all the commands and data which appear in the script files - the scr files where generated from that spreadsheet.
In CC3+ you can create a new map, and then run the script via Tools > Macros > Script File to insert all the stars as symbols into the map. You will have to replace all # with @ in the script file first though, as that has changed in CC3+.
Thanks very much!
One other question please, what does the SYMBOLISO command do? I have tried googling but cannot find it in the script command list I found on your site.
Thanks again!
It places a height symbol as the Stars in the Cosmo 3 style are. It expects the symbol catalog and the symbol name as input next, and then the location and height of the symbol.
You can always try out such a command by typing it at the command line in CC3+.
