World of Anngin (WIP)
I am combining The Herwin Wienk style with the Mercator style.
I think it looks good.
I'm going to try to draw a wind goddess blowing wind, a earth good holding the globe up, and a water goddess waves.
QuentenLoopysueEdERoyal ScribeRicko HascheMonsenMapjunkieJulianDracosLoreleiGlitch
  • Which style did you start with? I have been wanting to use the round outside of mercator for other map styles
  • I started with the Mercator template no bitmaps.
    Steps
    1. Deleted all the sheets except MAP BOREDER, GRID, BACKGROUND, and OCEAN BACKGROUND.
    2. Load CA64 Herwin Wienk in effects presets, save and add missing sheets.
    3. File, Load Drawing Properties, Drawtools style Annual Herwin Wienk.
    4. Tools, Import the styles bipmaps. I also imported the golden leaf from Sue's parchments.
    5. Change fills to what you want.
    Not sure if there is a work around but you have to make sure the bitmap you are using is selected in FS in the upper right corner.
    You with have to move your sheets up and down as you go to get the right order, add sheets before background if you don't want them disappearing
    You can change the white background fill to a parchment.
    I put my steps in just in case someone reading this post is unsure how to make it work right.
    Royal ScribeLoopysueJulianDracosRalfMaidhc O CasainMapjunkie
