World of Anngin (WIP)
I am combining The Herwin Wienk style with the Mercator style.
I think it looks good.
I'm going to try to draw a wind goddess blowing wind, a earth good holding the globe up, and a water goddess waves.
Which style did you start with? I have been wanting to use the round outside of mercator for other map styles
I started with the Mercator template no bitmaps.
Steps
Not sure if there is a work around but you have to make sure the bitmap you are using is selected in FS in the upper right corner.
You with have to move your sheets up and down as you go to get the right order, add sheets before background if you don't want them disappearing
You can change the white background fill to a parchment.
I put my steps in just in case someone reading this post is unsure how to make it work right.
