Daroe - Small fortified town in the woods
HadrianVI
Surveyor
Hi
I've started working on some small city maps with the Fantasy City Style, which is one of my favorite drawing styles for cities. I realized that I have to relearn a lot of techniques and workflow strategies. And I still have to get rid of some of the artifacts.
Hope you like it.
Cheers, Hadrian
Looks interesting.
Thank you.
Looks good to me so far :)
What artefacts do you mean?
Thank you. The Artifacts are a bit hard to spot in this resolution, but if you closely look at some of the towers, you see that the surface is somewhat dented. I think the issue is caused by two sheets with bevel lying immediately on top of each other, if I remember correctly.
You're probably right. It sounds like a form of transparency acne. Try switching out one of the fills (presumably the grey ones) for a slightly different shade of grey and see if that helps.
Thank you. I'll try that.
