problems with Lighted Bevels
HelenAA
🖼️ 19 images Mapmaker
I've gone back to an earlier drawing using bevels (but with new name) and i've hit a brick wall.
In earlier maps I've been able to adjust shading with the Bevel, Lighted settings but I have noticed that if I draw new shapes I can, sort of, play with the shapes but even when I put every shape onto its own sheet, having returned to the map I can't do this. It seems as they cling onto they're original settings for dear life. I've tried everything I can think of, short of redrawing. This is an impossibility for me and I wonder if anybody could tell me where I'm going wrong with the shapes.
PLEASE NOTE Not all the shapes are on separate sheets in the attached fcw
I can't see any issues with changing the bevel on any of your shapes. Are there any shape in particular you have problems with?
Two general things to look out for though:
Could you help me with a oddity in the map? It shows up as a shape with a green edge but when I try selecting it I can't do it - i've tried hidng everything else and still no success. All the polys are on separate sheets now - so many thanks for the help there.
It may be on a frozen layer. Use LIST to find out what layer it's on and check to see if that layer is frozen.
