Net framework question post net patch
                    Hi all
got home and bought CC3 and downloaded the compatible updates, now I've read that I need the specific version of .net to run them - but I know the verison 8 patch has done away with this.
What I want to know is: Do I have to still download and run the .net framework programme, to install the compatible programmes (dd2 etc) and then run the patch which will remove the .net need in order to install them at all? I guess this is a straight yes no answer. I suspect the answer is yes, but I am loath to load programmes on I don't need or want.
Can I unstall the net framework afterwards if the patch does remove the need for .net compatibility and support?
Also one other thing I'm using win 7 64 bit with a AMD x4 Phenom chip and 4 gig of ram, but CC3 seems a bit slow, especially when using sheet effects is this normal - even Photoshop isn't as slow, especially when doing redraws or zooming in on a space?
Thanks
Ab
Thanks
Ab
As for slowdown when using effects, this is normal. Remember that CC3 has to recalculate the complete effects set each time you add/remove/edit entities or change zoom or viewing area. Photoshop basically only have to calculate them once when applying them to image. Thereafter, they have changed the image permanently, and never PS never need to think about it again. Normally, you should work with effects off, and only turn them on when you are actually defining the effects, and when you are ready for printing or exporting the map.
Anyway not sure why CC3 with patch 8 didn't work but it didn't. Unless I needed to restart the computer - hmm, might give that a try!
Thanks
Ab
In any case, you should be able to remove .net afterward, the software doesn't really use it. It was only used by a single component, which was later replaced. The issue is basically that the installer belives it is still needed, so it checks if it is present.
I am sure tech support will be able to help you with your serial number issue quickly.
On a seperate note, I know that the CSUAC site is currently not available, but is there anyway to get the symbols that were being distributed? I know that many people downloaded it, I don't want to do anything illegal (hence buying and seeking to support PF etc with legal serials and what not) but I wanted to find out if there was a way to get a legitimate copy to use?
Ok thanks again
Ab
But you should have a look at the SMAC instead. It contains a lot more symbols than the CSUAC.
Monsen I know that you're an experienced user (I was to under CC2 I helped make maps for the FR atlas for instance and often took part in the symbol competitions, but a lot has changed since then) I really want to use CC3 to draw battlemaps. I know there is an atlas with it all on, but I am kind of hoping to get buy without as money is an issue. (Getting CC3, DD2 and the annual with the battlemap issue will easily reach over £60 and thats before even printing a single map off - eek!) One of the things I want to do, is to use CC3 with the DD2 compatiability. But I've noticed something, when you pull up a template with the bitmap function it puts in a background. To save on printing costs I don't want a background but do want everything else. Do you know what layer the background sits on? I want to delete it and remake the file as a new template for me to use.
Thanks again
Ab
When you create a new map using the wizard (Decide settings myself), you can just remove the checkmark for "Map Background", and you won't have any background in the new map.
And you'll do fine without the annual. It is very nice to have (And I highly recommend all of them), but you can draw anything you want even with plain vanilla CC3 without any addons at all. It gets easier with the addons, as you get a load of symbols, fills, pre-defined drawing tools and pre-defined templates, but it is quite possible to manage without.
Got one other question. My previous experience with Pro Fantasy is that they were very quick in responding. Reading Simon's blog I see that he said the office is effectively on holiday, so I am beginning to wonder how long it will take for them to respond to my query about my serial number. As it stands I've managed to get everything but the one module (DD2) running.
Have you any experience with tech support, I don't want to hassle them if its just that they are dealing with other things and will get to me or if I need to find some other route. I'm in the UK so I can call them for instance?
Anyway thanks mate you've been a big help.
Ab
But if they seem to take too long, you can try the alternate address located at the contact page, or just call them (numbers on the same page).
Registration login page
I have sometimes found serial numbers on my registration page I thought were lost.
Jim I did check there and copied and pasted from there to make sure I was correct to begin with and still no deal. Still not heard back from Pro Fantasy - so may try and ring them today.
Thanks all
Ab
