Sheet Effects Question
I'm working on setting up a template to draw B&W battlemaps specifically for large format printing as cheaply as possible. To that end, I want my output to be true grayscale.
I used OSR Dungeon Annual as the basis and imported in some additional fills from the BW Dungeon Annual.
When I'm working without sheet effects turned off, I am getting more or less what I want:
However, once I turn sheet effects on, it gains a yellow wash that I don't want:
This happens even if I delete all effects on all sheets. Apparently there is some over all effect that's being applied and I'm not sure where to remove that. Please help... :-D
It's possible you have an effect in the Whole Drawing category. In this map I have an RGB Matrix Process turning the entire map grey
To check your own map click the Whole Drawing radio button at the top of the effects panel. Anything there will affect the entire map.
That's it! Thanks so much (again). I figured it would be something super obvious once it was pointed out.
You're welcome :)
Don't forget to switch that radio button back to Selected Sheet before you move on with the map.
