Sheet Effects Question
I'm working on setting up a template to draw B&W battlemaps specifically for large format printing as cheaply as possible. To that end, I want my output to be true grayscale.
I used OSR Dungeon Annual as the basis and imported in some additional fills from the BW Dungeon Annual.
When I'm working without sheet effects turned off, I am getting more or less what I want:
However, once I turn sheet effects on, it gains a yellow wash that I don't want:
This happens even if I delete all effects on all sheets. Apparently there is some over all effect that's being applied and I'm not sure where to remove that. Please help... :-D
