Terrain selector not working
When I rightclick on Default Terrain within Dungeon Designer, it gives me the option to change to another terrain type in the Dungeon SS2A Style. All of the various Dungeon SS2 styles work, as does Dungeon DD Pro, Mercator Historical, and most of the Overland CC3 main style. But most of the other styles show the name of the terrain, but only display the sample (and only create on the map) the last terrain I used. I've attached the screenshot below. Does this indicate that I screwed up during installing the extra packs and just need to redo them, or is there something else that's wrong here?
Answers
Ah ok, you're up late : ) Thanks for the prompt response
Second question though. Not really related to the first but I don't want to make a bunch of new threads. I'm trying to export the map as an image file, and it is exporting, but all of my paths are messed up. I've added screenshots of those below as well; the first is what it should look like via screenshot, the second is what outputs when I create a PNG/JPEG/BMP.
More like up early, caught it before going to work :)
For line styles, look at this:
