Memory setting
Is there a way to set how much memory the program can use? I have a 12 core/ 24 thread processor and 64GB of RAM. The program seems sluggish trying to scroll or zoom on the included maps. So I am curious if there is anything I need to change in the setting somewhere to fix this issue.
Best Answers
The software is 32-bit, so it can't address more than 4GB of memory, which it should do by default.
That said, the rendering is CPU-bound, so unless you are manually forcing it to always use very high quality textures in the display speed dialog (a rather bad idea btw, since it won't affect visual quality, CC3+ automatically uses the right textures based on the current zoom level, manually overriding it just eats performance with no benefit) so the rendering speed is mainly limited by CPU-speed (Actual clock speed is the most important here, not the number of cores) .
Note that since CC3+ is a vector-based program, it will need to re-render your display every time you change view, it is not a finished bitmap just laying ready in memory as with regular image editors. The amount of work needed here depends a lot on your display size, for example a 4K display is 4 times as many pixels as as 1080p one, so it will also be 4 times as slow in that case.
Answers
Having sheet effects on also tends to make things slower.
Okay, Thank you. The CPU is liquid cooled and usually runs about 4.2GHz. However I do use a 4K monitor so that probably has a large effect.
