SS6 and grids?
Longtime CC3+ user but Schley's Isometric cities is my first foray into isometric and... I don't understand how these symbols are supposed to line up on a grid?
I've tried both the isometric and square grid, but neither is quite right. Is this normal for isometric sets?
Thanks!
I just tried square grid on an Iso, CA66, dungeon.
Vertical grid, while the iso dungeon is at an angle to the viewer's vision.
So I would say they don't work with iso.
I've been thinking about this. I'll try a few things and get back to you.
Ah, if I do a regular grid, it is vertical across the map.
Just below that in the Grid Overlay, it says Isometric (3D). Choose this one, the Isometric, and you will get the correct grid.
Here is the jpg and the fcw.
I did a little work on it last night as well starting with the angles shown at the base of each building, but since it's rotated quite a bit my solution involves using a transparent bitmap fill for ease. Is this what you were thinking of?
@CraigJ - if you still want a grid I've made the one I showed above available for everyone here:
