Maps of old Modules
                    Hello All.
Has anyone mapped any of the old TSR AD&D modules? Specifically I'm looking for A1: Slave Pits of the Undercity. I have all the modules, but wanted to have the maps in CC format so I could bring them into MapTool for my PlayByPost games. Just thought I would ask in case anyone has already done it.
Thanks!
Steel Rat
http://rpgmapshare.com
http://infinite-realities.com
Thanks!
Steel Rat
loyd
I put them up for download: Bunch o Maps
I remember dying in that moathouse!
loyd
edit: less than 60 secs to find. Win!
The Keep On The Borderlands perhaps.. that one had a bunch of interesting caves IIRC.
Haven't been mapping for a long while, so I'm trying to re-familiarize myself with CC.
I'm trying to make a water feature inside a dungeon which is a quarter circle, kind of like a moat. so it's not a slice of a pie, so much as a curved corridor filled with water. Don't know how to make a curved corridor, though.
Any ideas?
If you do, do the following:
- Click the All drawing tools button, Click "Advanced"
- Select the "Water, Default" tool
- Click "New" and name your new tool "Water, Curved Path"
- choose "Closure: Open"
- click "Options" and choose "Smooth"
- click Properties and set the line width to the width of your moat (e.g. 3')
You now have a drawing tool that you can use to draw your dungeon feature.
One other thing, how do I get the DD3 color (raster) objects as the default when I click the DD3 icon? It keeps coming up with the vector objects.
You can then later use the "Change like draw tool" function to turn this arc into the same look as the drawing tool I described. You'll find this command when right-clicking the Change Properties button.
You'll find the 'Change like draw tool' function by right-clicking the Change Properties button. The command line will then first ask you to specify a drawing tool (right click for list), then ask you to select the entities to change.
~Dogtag
