CD3 problem
I've only just bought CD3\CD3 (and some other add-ons) everything seems to be working fine except this problem with CD3; I'm not sure what that blank button is there for, and when I press it I get the attached error "Error loading file" - I do notice that the error mesage says CC2 at the top, not CC3 though. I'm running Vista with but I followed the help & have used all the appropriate patches (I think)
Go to your cc3 folder and run the program cc3menuconfig
That should clear it up, if not, someone else might have an answer.
To get rid of it, open the file city.mnu (in your CC3 program folder) in an text editor and remove lines #430 or #431 (whichever is present). Let me know which line it was.
When I switch to DD3 or CC3 the SM:Castles button appears & the other addon buttons shown in the screenshot above dissapear. If I hover over the phantom button the hover text reads Cities menu, so it is the SM:Cities button.
In city.mnu I don't get line #430 or #431, the lines skip from:
#428,SMC:[Castles Menu]{~|CMENU SYSTEM\smc.mnc;}~|SYMICONMR;SYMICONFLOAD Castle;MENUDM #castle.mnu;
to
#501,CC2LAND:[Default Landmass]{|DRAWTOOLSM;Land*;}|DRAWTOOLSM;Land, Default*;
It doesn't seem to be interfering with CC3,CD3 or DD3 in any way, so I'll ignore it unless anyone has any other ideas.
So, the phantom button has disappeared for me - I hope the info helps you bugfix.
