Live Mapping: Monthly Symbols for Mike Schley Overland
Hi Everyone! :D
In this week's Live Mapping session Ralf will present the free monthly symbols by Mike Schley that Profantasy have been releasing since June, by using them in an overland map.
Come along and join in, or watch later :)
30 minute call :)
Missed most of it do we know when it will be posted?
You can watch it now.
There seems to be quite a long bit at the front end with nothing happening, but it's right here:
https://youtu.be/Iy0qiNW1lMI?t=291
Just a general comment about live streams, YouTube always needs to process them after they are done, so it is out of our hands when the video will appear, but usually it will be a couple of hours after the stream ends.
I got around to watching the episode this week (not live, obviously). A couple of quick things based on the attached pic
Thanks for doing these streams - I feel I have learned a ton about this software over the last year by watching them
Might be worth tweaking those two trees on top of the mesa, as if they're actually growing there, they should be in front of the jungle trees behind them, which they currently aren't. Or if they're part of the jungle, their bases need to be behind the mesa instead.
Fine-looking mini-map, regardless! And yes, the livestreams are always worth watching, whether live or VOD later.😊
I was having difficulty just getting those two trees (I moved some others back). This view is zoomed in, so at a normal view they are not as obvious.
You should be able to select them if you zoom right-in to just the trees. If you end up with the mesa, or other trees selected as well, you can deselect what you don't want by holding down Ctrl and left-clicking on the items to deselect.
