Issue with annuals and blank template
Jeff B
Betatester 🖼️ 37 images Surveyor
I have been trying to learn CC3+ and keep running into some issues. Following the Live mapping Ralf did with the Fantasy Tavern annual here is what I'm getting. I have done an uninstall and reinstall and same issue.
Also if I select a drawing tool from a different annual they are always the same bitmap as the current background is that normal or I'm I doing something wrong. Do I have to import every bitmap I want to use into the map.
You seem to have the drawing tools for SS4 selected in the drawing tools dropdown box at the top right of that dialog. I also have a blank background when I open a new map for that template, but the fills are there. It's just that none have been selected for the default background in the template.
When you create a new map try selecting a fill for the background. There should be all of these and more available.
When the new map opens select the "Dungeon DD3 Color" style from the style box in the drawing tool dialog
If none of this happens correctly please contact Tech Support through your account page.
Sue I'll contact tech support as I have the fill but selecting any of the fills still creates a blank background
I didn't go that far myself the first time I tried it. I only checked they were available. However, I can confirm that the background remains empty when I do select one.
Probably best to contact TS ;)
I will but it appears the web site is down as it's currently unreachable for me.
It seems fairly normal to me. I'm in the UK.
There might be a broadband issue somewhere on the line between wherever the page is kept and you.
