issue with font
i was typping my map names, and noted this 2 names like as "double".
went to tect sheet to look if i had typed 2 times same name in same place and dont... also all other 32 names was ok.
this appear in opened cc3+ also when i exported (this image is from exported map) in both - jpg and png
someone can help me with a light why this happen? thanks
Do they render to an image output like that?
when program was open this issue didnt appear.
just when i export and just for those 2 names on total of 35 wrote names in this map
i export in jpg and png to test... appear equal on both (the image i upload in bw is the exported image).
believe was the first time i noted the issue.
p.s. both names i deleted and wrote again in same position and also still happen.
What are your export settings?
These are my settings - for a good quality hi res general export. Notice that I have quite a lot of antialiasing, which can smooth out the jagged edges of things quite nicely.
You get to them by clicking the Options button in the save as dialog, once you have picked your bitmap file type.
equally is first time that happens to me. strange :/
this is the image on cc3+ with sheet efects on, and dont appear this bug.
ive deleted the names once more and put them again... now no problem :O
That is indeed a strange one!
Well, I can't see a reason for the anomaly, but if it happens again let us know.
never happened before, because this i post to let pf know
That might be an indication of an export doing a second rendering pass with a little "hiccup". Try this:
Type EXPORTSETMPPP and hit enter. The command line will show you a number. If you haven't ever changed the setting before it will be 4000000 (four million). Type 40000000 (40 million) and hit enter, then try again.
