Problem With Fonts
Hi All,
I've been using CC3 this evening to create a new map and a new strange bug seems to be happening. When i try and change the font it just wont let me select one. Anyone got any ideas ?
Regards...
Regards...
The selection method occasionally gets messed up when a macro or command doesn't complete correctly. I'm guessing that this might be why the text selection isn't working.
Steve
Are you unable to select the text you wish to change, or are you unable to actually click on a new font in the list of fonts in the Text Properties box, or are you able to select a new font in the list, but nothing happens when you click ok?
If you cannot select the text to change, make sure you click on the baseline of the text when selecting it, and that the text is not on a frozen layer. Also make sure you use the "Numeric Edit" tool to change the font, and not the "change properties" you use on other objects.
Also, assuming that this didn't help, what happens if you start a new blank map, and try to change the text there? Does that work? Is the problem both when you are creating a new text, and set the font upon creation and if you try to change the font of an existing text, or does it only happen in one of the cases?
Thanks for the help but im really not sure what just happened...
I'm having exactly the same issue, clean installation patched to 3.40. When I bring up the text properties box, I can change all the options, except select a different font, I can scroll through the available list of fonts, but am unableto select any of them. All text is stuck in ariel.
Mel
Note: I deleted the separate thread posing the same question.
reapplied patch 8 - no joy.
Rebuilt system, clean copy of windows xp and clean install of CC3 no joy. can open the dialogue box, can't select any fonts
Mel
Everything unchecked.
Partioned hard drive and installed Windows 7 Enterprise. Clean install of CC3, no patch. Low and behold i can select the blessed fonts!!!!
On a roll, so tried to install the patch, after an hour the patch was stuck in some kind of loop, and refusing to install.
Going to re-download the patch, perhaps something went subtly wrong in the original download.
BTW, unpatched app appears to work fine on Windows 7.
Mel
Re-downloaded the patch, applied and everything seems to be working. Will try on the xp partition.
Cheers
Mel
Any suggestions????
Mel
