the dreaded red x symbol
HelenAA
🖼️ 5 images Surveyor
What causes the infernal and annoying red x symbol in maps?
I closed a map before my mid-day meal and went back to it just now and was greeted by a background full of the annoying symbol.
I did rectify things so no harm done -- this time!
Cc3 either cannot find the item because it isn't there. Or the path to it is incorrect.
I had this happen to me several times.
Hi Helen,
Jim is correct, the red X means there is a link to a bitmap file (external to CC3+) which CC3+ can't find. This can happen if you moved the map to a different computer where the add-ons/bitmaps are not installed, or you imported a bitmap relative to the location of the map and moved the map to a different folder.
The example you attached refrences a few custom symbols in a folder /User/Throk, which I (naturally don't have) and therefore appear as red Xs to me. Everything else seems to be from Cosmographer and works fine here.
I don't move symbols! I can go into CC3+ in the morning and everything is OK but the next time I open the map I see the symbol that I know means that CC3+ can't find the symbol(s). Next time it happens I'll try to take a screenshot, but this time it was the background.
I once had a similar problem. In my case it was solved when I ealised, that the USB slot the external Harddrive on which the symbols were was damaged and only worked some of the time.
It is certainly not normal behavior for CC3+ to intermittently show red X'es for images that worked earlier, but there are a few external factors I can think of:
