Group, Ungroup, Lock and Unlock
mike robel
🖼️ 15 images Surveyor
In what was clearly a misguided attempt to rotate my entire map in CC3, I used Group and drag selected the all the sheets and then "did it", followed by Locking it. Uncharacteristically, I then saved the file rather than creating a version. Rotating failed (for unknown reasons) and I then tried to Unlock and Ungroup the sheets.
Since grouping and unlocking prohibits appears to make individual changes impossible, I will likely have to redo the entire map unless the smart folk here can point me in the right direction.
Even worse, I found rotating the map was not required in the first place. I failed to tell the program to use the scale factor rather than fit the image to the page when printing. Grr.
I can attach the FCW if necessary, but I am at the car dealer waiting on my car with my traveling computer which does not contain CC3.
Thanks!
What was the problem with ungrouping the entities? Once you ungroup everything, it should be editable just fine. Same if you unlock groups, then CC3+ will behave as if the entities aren't grouped at all, allowing normal editing.
Groups should not be applied across multiple sheets though, since a group can only be on a single sheet, this will pull all entities onto the sheet you create the group on.
Well. I grouped the sheets and it does nothing when I try to select a sheet. When I do ungroup, then try to hide everything but a single sheet, the whole drawing disappears which makes sense if one is not supposed to group sheets. :(
Here's the FCW, just in case I am doing things wrong.
The problem is that everything is on the TEXT sheet now due to the grouping, so you'll need to put things back on their appropriate sheets.
Aha. I think it might be easier to just redraw the map. It's pretty small as things go for me.
Because that never occurred to me and I probably only use 30% of the program's capability. :)
Right there with ya, brother.
Cal
Yes. I can identify with that as well. The thing about CC3 is that there are so many different ways of doing similar things that its relatively easy to forget things too.
