easy way to convert a city map to an overland map ? accidently picked wrong template
I was starting a map of the area around Keeper Tower... I accidently chose a city template.
It needs to be around a mile across, not 1000 feet.
I saved as a png file and inserted that into an overland template which I am working on now.
But for my future tribulations, Is there an easier method ?
Also, the template type isn't that important. If you need an overland map as small as 1 mile, you could probably just use the Resize Drawing Area command and resize your city template to 5280 feet. You can just as well keep working in feet at that scale.
Tried both.
