Export size for VTTs
JoeyD473
Betatester 🖼️ 2 images Traveler
So what is a good size to export a map I make for VTTs such as Roll20?
I just started Roll20 about 3 Weeks ago. I found, that exporting CC3 maps for use in Roll20 is ok, if you set the options for the JPG- File to a resolution of 70 pixels per inch. Also, you should restrict image to map border, otherwise you get a real large image of white with a little dot of map on it.
Hope, this helps,
Arastor
